Thanks, that works. ![]()
What is the default behavior of the Midi-to-cv module if there’s no MIDI in. Does the clock on screen output anything on the clk pin?
All output pins including CLK and RST can be mapped from the midi settings menu
So if CLK is mapped to clock and source is set to internal you will have a clock signal on CLK output according to bpm you set
Awesome! I’ll have to try again and maybe do the reset, I dunno. It just didn’t progress my sequencer when I tried it the first time.
I have two issues or questions about the MIDI/cv module.
First, I couldn’t make it work, probably due to my ignorance on the matter, but I might have found the answer: the kit I bought (synth starter) doesn’t include a VCA. Can I make MIDI work without it?
Second, this might be a bug? The MIDI module turns off when the audio out AND the oscillator modules are plugged with it. Is it a lack of voltage? (I use a 9V battery through the DC in.)
MIDI itself does not care about any VCA. But normally we want to do something with the gate output of the MIDI/CV-converter, so it can start and stop the tone. A VCA usually does that job, but a filter can also work, or a LPG.
A standard 9V block battery does not deliver much power, probably not enough for three of the bigger Microrack modules. Look at the LEDs of the power module: if they dim or go completely dark, there was not enough input power to keep everything running.
Thank you for your quick answer. After I posted this question I ordered a variable power supply, I imagine I will “crank” it up to 12V. ![]()
I need to explore more with the filter and envelope too.
Cheers!
Little update on my part.
I received the variable power supply and dialing it up to 12V does the job.
I also kind of was able to make MIDI work, although I can’t make it stop to sound between notes yet. It’s a learning experience.
But I have to say I ordered a couple VCAs.
you should be able to use the filter as a kind of vca because it cuts the sound down completely or almost completely when closed. So try setting it all the way down to zero and modulate the frequency with an envelope.
thanks, good call, will definitely try it
Received mine a while ago but forgot about it until this week. I’m totally new to modular synthesis. I got the DIY kit and the subtractive addon. I was able to get a midi keyboard hooked up and I got the envelope controlling the filter as recommended in this thread. However I have two issues:
- The tuning within an octave is off. When I play a C1 and then a C2 (one octave up), they are off by one semitone. In order to get the same tones one octave apart, I need to go 13 semitones (C1 and C#2) for it to sound like an octave. everything else is scaled that way so that when I play a 5th (C and G) the G is ~half a semitone off. Any idea why?
- The esp32 board displays a page saying BPM: 120 and I can click to another menu but I can’t find the oscilloscope. I don’t see the same “test mode” screen that a previous commenter showed an image of.
Also, for the esp32 midi board, was does the output pin A do? I know B and C are the pitch and gate.
Thanks for the help.
If you have the stylo module you could compare the notes from that to see if the midi→cv module is consistent. If you have a multimeter you could check its pitch CV changes by 1.000V for each octave. The most likely issue is the oscillator’s scale not being set correctly, there’s a trimmer potentiometer on the oscillator module (labelled 11 on diagram) which needs a very small, flat-bladed screwdriver to adjust it. I wrote a short article (from of a series) with an accompanying video on how to tune this.
Of course if I had just googled “microrack oscillator tuning” I would have found your article in the first place! Thanks for putting that together for the community and and for replying to my message quickly. I’ll give it a shot tonight. My kit didn’t come with the stylus module but I have other midi controllers I can test.
I followed the article and was able to get pretty close on tuning. Thanks for the help. I noticed some odd behavior with the envelope module even when not in the signal path, and made this post about it.
However, for the esp32-module, I still have the following questions:
- The esp32 board displays a page saying BPM: 120 and I can click to another menu but I can’t find the oscilloscope. I don’t see the same “test mode” screen that a previous commenter showed an image of. How do I get it to the oscilloscope?
- What does output pin A do?
To get to oscilloscope mode press and hold the button (the one the left from knob). Pressing agains will change view type (two waves separately or together)
All output pins can be remapped from MIDI setting menu, and depending on the setting it can be either mozzi oscillator (produces sound) or MIDI gate/CV/cc signals (produces voltage)
