Utility modules (jack, power, etc.)
The jacket module is a very simple passive module designed for integration with modular systems and synthesizers that operate with modular signal levels. Typically, in this case, they have mono jack outputs.
To connect line-level signal sources, an input jack module is used, where you can set the gain.
