wow, thatās crazy rhythm pattern, how you achieve it?
sounds beautiful! Which FX you have on master?
Thanks, this is an old video, so I donāt remember for sure, but most likely I used Soundtoys Echoboy Jr as a looper and Valhalla Supermassive as a reverb
Just a basic jungle/drum and bass/breakcore recipe: take an amen break, speed it up to ~150 bpm, chop into slices and rearrange as you want. Typically a sample of acoustic drum break is used, but here Iāve done a very minimal midi transcription of an amen break and worked with that.
Testing a few new things: envelope for glide, external trigger input. Both worked fine, but one needed careful adjustment. ![]()
Now if I only could play a melody with the other handā¦
(also: donā use the stylus keyboard with those black cables with the pin at the end! The gold plating on the ākeysā wears off quickly if it is continuously scratched by the sharp edges of the pin. The rounded end of the croco clamp works much better, except I have used both of them for the oscilloscope connections)
Edit: Oops, the manual of the RD-6 says that its trigger pulses are 15V, which is three times what the Microrack envelope module expects. Hooray for Microrackās defensive circuit design, which prevented any damage!
actually inputs must handle up to 12 V but most of the inputs starts with 10/100k resistor which can protect internals.
good warning.
I think we should make kind of errata with all know issues
